Cheap cover for V3 pan
So I have a V3 pan out in the weather without a soffit over it. Add northeast winter temps jumping above and below freezing- unit locks up due to frozen ice formed around the swivel points. So my neighbor with a few V3 pans came up with adding an umbrella over the units! Took a plastic sour cream lid and mounted it on the top post. He used tape, I drilled a hole and used supplied screw. Works perfectly! I tried to add pics but site won’t allow.
Now learning how to stop snow or freezing fog from screwing with motion detection. Any ideas?
[Mod Edit] Updated topic camera tag.
What error did you get? or what happened when you tried? you should be able to post atleast one image, and more once your forum trust level increases with use.
