i’m trying to return to the last stable firmware but the manual update method won’t work. i’ve tried the same sd card with other cams and it worked but not on the beta firmware. i’ve tried older firmwares and even the rtsp.
This Firmware has a note associated to it as follows:
- Due to the security improvement on this firmware, you will need to go through the factory reset process for your camera if you go back to firmware 4.36.9.139 or below.
Have you tried a factory reset first?
here is a link on factory resetting the device:
oh wow i thought that was informing me i will need to setup my camera again after resetting. i didn’t think it was a separate step needed to be done first
never mind didn’t work either
