Can Windows 11 LTSC Keep Old Windows 10 PCs from landfills
I was hoping to keep my trusty old i7 PC after Microsoft stops supporting Windows 10 in October of this year. I really don’t care for any flavor of Linux, so a Windows alternative would be nice to keep my old PC alive and useful. I was hoping for a version of Windows that doesn’t require all of the requirements of the regular Windows 11 but is still updated with security patches. I was hoping for a less restrictive Windows 12. I can buy a new PC, but my old i7 is too useful to throw away.
Last night I found a video that says Windows 11 LTSC is what I have been waiting for.
Has anyone installed Windows 11 LTSC on an old PC? This seems to be a major problem solver. I don’t need tech support or feature updates, but I do require security.
I asked AI the following question …
What is Windows 11 LTSC. Can it be installed on older PCs?
Windows 11 LTSC (Long-Term Servicing Channel) is a specialized version of Windows designed for devices that require long-term stability and minimal updates. It’s commonly used in industries like healthcare, manufacturing, and retail for fixed-purpose devices such as ATMs, kiosks, and industrial systems2. Unlike regular Windows versions, LTSC doesn’t receive feature updates, focusing instead on security and critical updates, making it ideal for environments where stability is crucial.
As for installation on older PCs, it depends on the hardware. The minimum requirements for Windows 11 LTSC include a 1 GHz processor with at least 2 cores, 4 GB of RAM, and 64 GB of storage4. However, there are optional configurations that allow for lower specifications, such as 2 GB of RAM and 16 GB of storage. TPM (Trusted Platform Module) and Secure Boot are optional for LTSC, which might make it more compatible with older hardware4.
If you’re considering installing it on an older PC, it’s essential to check the specific hardware against these requirements. Let me know if you’d like help with that!
Yes. I would like help with that! I have an old Dell PC with an i7 and meets all of the requirements. I don’t or can’t install the normal version of Windows 11 and may need to use this solution to save PCs from the landfills?
That’s a fantastic initiative, Steve—giving your old Dell PC a second life is both practical and environmentally conscious! To help you get started, here are some resources that guide you through installing Windows 11 LTSC on older hardware:
How to install Windows 11 LTSC Made for Old Computers: This video provides a step-by-step guide, including how to create a bootable USB and bypass certain requirements like TPM and Secure Boot.
How to install Windows 11 LTSC for Old Computers: Another detailed walkthrough, focusing on optimizing the installation for legacy systems.
Finally Windows 11 LTSC Official Is Here: A concise overview of the installation process and the benefits of this lightweight version.
I haven’t heard of that before now.
I do need to do something about a couple of old laptops though. Sound weird to call a laptop from like 2018-2019 old…they still work great (I got them with top components back then), but I am concerned about lack of security support on Win 10
I need to learn how to “find” an non-eval copy.
or ,
