I have the new Wyze Cam v3 PRO model. To view the camera image on your computer. I installed Bluestacks which can run android apps on Windows 7 thru 11 and then clicked on Playstore to download and install the Wyze cam app. Works great so for. I tried LDPlayer but it has been freezing of late so I switch to Bluestacks Download BlueStacks - App Player on PC - Windows and Mac
Install windows 11, because you know, you want OS security update. Then you can just install wyze app directly, as you can install android app on windows 11… it work 100% flawless and require no emulation!
I will keep this in mind but my pc is from 2015 and cannot upgrade to Windows 11.
My pc is also very fast so really no need to upgrade except for the new look and the playing of android app ability.
