Really simple and works perfect. Simply download Bluestacks on your PC. Open it and load the WYZE app. Once you do you will see the exact same view you see on your phone. I have 8 V3 cameras and they work perfect. I wish WYZE would modify their program to allow for multiple column so that you don’t have to keep scrolling down to see all your cameras. I’m sure they have no interest because they want to sell you their worthless PC connection. Once you set up Bluestacks you’ll realize how fast and easy it is to use and FREE. Then just add a shortcut on your PC screen and your cameras open instantly.
One change that would be nice I think WYZE can easily fix. Maybe somebody can add it to their wish list. It would be nice to allow 1, 2, or three columns so that people with multiple cameras can see them easily instead of scrolling down a long list.
It is quite handy. Although I used gmail on it and it said an unauthorized Pixel phone has logged into my account. WTF? I don’t have a Pixel phone. Turns out Bluestacks was emulating a Pixel phone.
Beware, it won’t run on M1 and M2 silicone Macs. Bluestacks 5 is useless as it only gives you option to install games, not apps. At least I haven’t found a way.
Bluestacks 4 will run on Intel Macs but you will need min 8 Gigs of VRAM if you are using HighSierra or higher.
That is incorrect for Windows devices. It simulates various models of Android phones and you can add any app or game you want. I can’t say the same for iOS.
I would just like to add my 2 cents. I have tried the free version of Blue Stack, Nox and Memu. And I don’t care for all the commercial adds they have.
I stumbled across this app that I am using now with less commercials. LDPLAYER. Combine this with Windows app ‘Windows Top’ I can setup a window that I can monitor while on the PC.
We tried running it on the android 11 and 13beta on BlueStacks5 both did not work, but we have malware bytes installed and it complained about connecting to an ip address that is often associated with Wyze and AWS.
so the cameras would not run. The only camera that worked a little was the floodlight cam pro, it let us read the sd card.
all the other cameras would just show lists of events.
We really really need wyze to release a desktop app.
