Can the OG telephoto camera work with the flood light?
Will the OG telephoto work with the floodlight. Can it be powered off of the flood light as a second camera and can motion recognition from the OG telephoto camera turn on the flood light?
Only a V3 can control the Floodlight directly.
Yes
Not directly in the floodlight controls. However using a rule, you should be able to set this up.
Use the OG Motion detection as the trigger and the V3 w\ the Floodlight as the action to turn on the floodlight.
Thanks.
