Well since the new iOS 18 was installed on my iPhone I no longer can see my cameras on my WiFi at home. If I go out I can see them as long as I’m not connected to my home WiFi. Connected to any other WiFi at work or anywheres else I can see them or if I turn off my WiFi at home. As soon as I turn on WiFi at home they go into Failed to connect error code 22005. Very frustrating. I have done everything to reset and reinstall but not working. Have contacted Wyze support but no help so far. If I can’t get them working I will take down all 8 cameras and go back to my ring cameras…
Need to toggle on Local Network permission under your iPhone’s iOS settings for the Wyze app:
Did that rebooted phone and still doesn’t work!!!
Has solved the exact issue you’re describing for many others. Have you gone back in and made sure the setting “took”? Are you running the latest Wyze app? Make sure you’re granting the permission to the Wyze app and not something else (yes seems obvious, just mentioning it). Only other thing I can think is perhaps having that communication blocked while trying to connect has caused something to get “confused” and rebooting your phone (again) and your router and cams also will clear it out? Do all 3 before attempting to connect to them again.
This is a new “feature” introduced by Apple, may need to seek support from them if you aren’t able to get it working.
