Cameras fail to load video in IOS 18 when connected to the same access point/wifi
IOS 18.0 official release and beta versions will not connect to cameras within the app when on the same wireless access point. Failed to connect Error (code -22005)
It does not matter if I’m using 2.4 or 5Ghz on the same access point, it will not connect. On another wifi or mobile data, it connects fine.
I had hoped WyzeBeta app might have had fix, but it doesn’t. My daughter uses the latest IOS 17 update & has no issues.
Private relay off or on makes no difference. Enabling or disabling VPN throws the same error.
This applies only to live, storage or cloud events aren’t affected.
WyzeBeta 3.1.0 (5)
Never mind, I figured out that I needed to enable Local network access in Settings > Apps > Wyze >> Local network enabled.
Yep, new thing in IOS 18 beta/RC, there are a few threads here on it. Wyze will need to add that prompt in the app to enable it once 18 goes production.
