Wyze cam V2 unable to connect to camera
I’m running the iOS 18.1 beta on my iPhone. Ever since iOS 18 beta was released, I have not been able to connect to the cam. I’ve reported this to apple too. Blue light on camera. Gets an up address. But when I try to connect I get:
Failed to connect.
Error: (code -22005)
Or
Connection failed
Please try: 1. Force close app and retry
  1. Power cycle the camera
Which I have tried with multiple versions of the beta.
I’ve removed the device and successfully rewarded it but with no luck.
Reaching out here to see if any of y’all can help.
Same issue here. And trying to get ahold of someone at customer support is impossible. Have you found a solution yet?
I haven’t heard anything yet
I’m thinking it’s the WYZE app and ios 18 beta. I didn’t upgrade to 18 beta on my iphone and everything is fine.
Isn’t that the risk you take installing beta software?
We will see this month when the ios 18 become available for all…
Have you tried from outside your home wifi network? Another poster said theirs would not allow local connectivity until they went in and gave some “local” permission to the Wyze app.
There was another thread here where someone could not connect to the cams from their home wifi (but could from outside of it) and they had to go in and grant the wyze app some local connectivity permission in IOS 18 beta.
I’m on iOS 18 as well. I have multiple cameras and only 2 won’t connect, so I don’t think that’s it’s an iOS 18 issue.
Did a soft reset of my iPhone and now the cameras connected.
have same issue today on ipad os 18 released today.
Settings >Apps >Wyze >Enable ‘Local Network ‘
Restart Wyze App
that worked allow local access thanksbworks now ios 18;release
