Can’t connect to any camera on LTE; visible thru Wi-Fi only
none of the cameras I own (V2, V3 , Pan) will get past the message “connecting camera 1/3” when I’m away from home on cellular LTE, however On Wi-Fi at home everything connects.
I’ve tried unplugging for 30 seconds, and that doesn’t work, is there maybe some network problem or a possible bug in the firmware? I have around 8 cameras that all do this consistently.
I have a few Wyze outlets that I can turn on and off through cellular but only the cameras won’t connect. Anyone have a suggestion? Thanks!
You’re going to want to turn off any fancier firewalling and traffic management / QoS at your router - these almost always make things worse. It sounds as if your router is somehow blocking the P2P sessions required for this to work. Also avoid IP6 if possible.
The good news is you should be able to test at home just by temporarily turning off WiFi on your phone.
Maybe you should read this entire old post about IPV 4 and IPV 6 settings on your phone>
I have iPhone/Verizon. Settings>Cellular : Is WYZE turned on on your phone?
This issue actually started recently within the last maybe 3-6 months, I know on an earlier firmware version I didn’t have this issue. I am able to control my outlets through cellular just fine. I checked the iPhone settings and wyze is enabled for cellular, I haven’t altered the settings or firmware of the router in a long time so I’m not sure it’s a network issue on my end but I’d be happy to be proven wrong. I’ll read that thread
Hi,
I have the exact same issue. Have you fixed yours?
I own several Wyze cams and I have been able to stream them all without any issues, whether on Wi-Fi or cellular, until suddenly (around the same date you posted this topic) they all stopped streaming over cellular. To date, they still function with no issues when I connect my iPhone to WiFi. But every time I leave the house and I am nowhere near Wi-Fi spot, my iPhone won’t stream any of the cameras over cellular.
I did try to reach to Wyze support. They offered several troubleshooting “attempts” without a success.
I am having the same problem. Both cameras work fine on the wifi network, but as soon as I leave the house and use LTE to pull them up it does not work. Ill come back to this thread if I figure anything out.
