Can’t access cloud recordings
Since 830 or so this morning I have been getting - “Failed to load from Cloud Server, you can view the event from your backup local storage.
Jump to SD card” —— on my doorbell cam. Tried restarting it several times. None of my Wyze cam v3 or v4 are having this problems which there are 15 of them.
Anyone else having this problem ?
I am having the same issue, has support helped any?
Same on both V3 and V4. Looks like server issue.
Since the new update all my cams are noticeably quicker to connect and so far no problems accessing the cloud.
As I said, probably a server issue. Everything is fine now.
Been having this issue intermittently for the last few weeks. But this last go around it’s been over 24 hours of events that I can’t load from the cloud. I’ve reset the cache, the camera, the app, nothing is fixing this. All my other cameras events I can access just fine. Only the bulb cam is having this issue.
Ever since the update now I have to go through as card so do we get reimbursed for not having cloud coverage now? Cuz this is a crock of poop! Not happy. They need to fix asap
Wyze Cam V3 and V3; it’s been about 6 days since my cameras started failing to load from the Cloud Server.
Troubleshooting hasn’t helped much either. Adding the cameras back after deleting them appears to “fix” the issue for a few hours so I’m relying more on my SD cards instead.
Hoping that this gets fixed soon!
I was having issues with one camera, now it is like 5 of them stating failed to load from Cloud server. I have done the advice, with no luck. I really don’t want to re-add every camera. This has been going on for weeks.
This has been an ongoing issue for me with no resolve.
This is an ongoing problem with all my cameras since I started using Wyze cameras. Still going on.
