Dont know if I’m in the right place to post. I have 2 V2 cams and a outdoor cam set up now, I get all the event recordings but every time I sign into the app I can’t get any camera to show a live video, it always try to connect 3 times then stalls out.
Been having the same issue on WOC off and on the past several days.
Welcome to the Wyze community @Tonysebenaler!
What firmware are the V2 and outdoor cameras using?
What app version are you using? Make sure it’s updated.
As far as I know everything is updated current as I did the updates 2 days ago when I installed my new outdoor cam
I’d also try power cycling the camera.
https://wyzelabs.zendesk.com/hc/en-us/articles/360053907712-How-to-power-cycle-your-Wyze-Cam-v3
If that doesn’t work, try a factory reset.
