Can I get a text message when motion detected?
I don’t see where the option for this on WyzeCam3.
I only get a Wyze notification.
Thanks!
Sorry, push notifications only, at least from Wyze.
If you have an IFTTT membership you can probably create a macro to send you a text message.
There are probably some other complicated ways using Home Assistant, or Tasker or Google or Alexa Webhooks or something, but those methods are beyond most people’s capabilities.
It is possible to do, but in general the answer you are looking for is “No,” since Wyze does not offer this as an easy built-in setting.
3 years. “Maybe later”.
I just tried IFTT as an option but all it seemed to do was capture my Push Notification and prevent anything from reaching my phone !
