I have 3 cameras with Cam Plus. I have set each camera to record on motion if a person is detected. However only 1 camera will let me change the event notification choices. The other two cameras are whited out (no dropdown of choices). Should I be able to modify each camera separately for type of event notifications that I want? (E.g. person, pet, vehicle etc.)
I reread your post and realize zed I miss read it.
The answer to your question is yes, each camwra is independent of each other and can be set how you want.
Can you post a screenshot of what you are seeing?
Can you also provide
- the firmware version of the camera
- the app version being used
- if you are using iOS or Android
It looks like I somehow had record events flipped off for 2 of the cameras. When I correct that, I am able to modify event notifications motion settings for those cameras independently. Thanks for your help.
Glad you found the solution!
