Every time I open the Wyze app, and click on my group of cameras, they don’t load. What’s going on with this. Any ideas? I have to force close the app a few times for them to finally work.
Wyze is working on the fix. There was an issue with the latest hot fix. Temporary solution is to remove the cameras from the groups.
Ok I did that. They’re working. Can I regroup them. Or will I have the same issue? Thank you.
You will have the same issue. Keep them out of the group for now until Wyze releases a new app.
Don’t regroup then until the hotfix is released
You beat me too it!
Quick on the draw
Awesome! Thanks guys!
