I’m signed up for CamPlus on two existing V2 cameras that have SD memory cards, and thinking about getting a third V2. Is there any reason to get a SD card for the new camera if I plan to use CamPlus with it?
yes, lots of reasons…
- the cameras often complete miss events which would mean no recording whatsoever
- the recordings often stop prior to the activity ending despite what they say
- if your wifi is out or connection temporarily lost then the local recording on the microsd card is the only possible record of activity.
32gb cards only cost $5. get one!
OK! I like those reasons - and I’m assuming I should set local storage to continuous recording to avoid the missed events/early stop issues. Thanks!
I put my SD card on continous recording from day one. I have been able to save clips of things that otherwise would not have been captured. Like the alarm going randomly of for a neighbors vehicle. Used the video to convince them to correct the issue.
