Cameras Missing from adding to Cam plus
I have multiple cam plus subscriptions and I can not add my floodlight camera because it does not show in the list. It is on and I can view it in the app and I get basic notifications. I also have 3 other cameras in the app that currently are not plugged in, only 2 of those show as optional to add to cam plus although I do use all 3 intermittently.
Do the cams that aren’t showing up have a cam plus trial? I think your not able to put the cam on a real license until the trial ends
They did but it expired months ago,
Try clearing your app cache in account > app settings, then force close the app. Check if anything changed.
EDIT
Also try logging out and back into the Wyze app
So it turns out I had a monthly subscription for 2 cameras that I canceled months ago. That seems to be the reason the cameras didnt show as they had been assigned to that subscription however you would Think that when a subscription was canceled the cameras would be “released” back in to the available que and not just disappear. Guess not.
Interesting, good to know for future troubleshooting. Glad you got it resolved!
