Camera won't pan saved waypoints
Camera pans properly in Preview mode but stops panning when waypoints are saved.
Do you have Pan Scan turned on?
Is there a toggle for that? I have waypoints set. It pans in preview mode but stops panning when I save.
Yes. When viewing the camera, on the row of icons below the image, swipe left which will bring up addition icons. Two of them of interest here are “Track Motion” and “Pan Scan”. When turned on, the icon will turn Wyze green.
Thanks! I was having same issue. That button should be prominent on first screen, not something I have to dig around to find
Thx - I didn’t know to swipe left on the icons. That worked!
I had no idea I could swipe for more settings!!
One of my pan cam v3’s motor is messed up. It’s only about 3 months old. On the app, I unplugged and plugged it back in, set it up, deleted pan settings, and turned off detection and track motion. It worked for about 2 weeks when I re-mounted it, but it’s doing it again.
“Messed up” does not tell us anything. What’s happening or not happening?
