Camera off line all the time
I guess the Wyze camera it is the only camera in the market that off line frequently. Can they update their software so when the camera is off line it can automatically restart ? Think about it, when you are away from home or on vacation and try to check the camera, it shows the camera is off line. So frustrating!!
Frustrating when you’re away and live view just says offline. Wyze does not auto-restart a camera that drops off Wi-Fi, but if it is a plug-in cam, putting it on a cheap smart plug you can toggle from your phone is the closest remote workaround. Next time it drops, check the signal in Device Info; if it is worse than about -70 dBm, moving the cam or adding a closer access point fixes it better than hoping for a software restart.
My Front Yard V4 Pan Cam goes offline frequently, and I can’t connect to the live feed several times a day. I thought it was a rain problem, so I had put a rain shield over the camera. That hasn’t helped.
Since I can’t reach the camera to unplug it, I deleted it from the app, and attempted to rediscover and add it, as that had worked before. After several days, the app still couldn’t discover the camera.
I ordered the Wyze Outdoor Smart Plug, so I could turn off the outlet when I needed to reset the camera. However, the V4 Pan Cam doesn’t plug into the Smart Plug properly. It only plugs in about halfway into the plug. So that’s something to keep in mind with the Wyze Outdoor Smart Plug.
I also ordered a new V4 Pan Cam to replace the Front Yard V4 Pan Cam.
Since the Carport V3 Pan Cam suddenly stopped panning a few days ago, I planned to move the V4 Pan Cam being replaced to the carport, as it’s a more protected location. However, even though the V4 Pan Cam is less than a year old, it’s completely dead.
Meanwhile, the V4 Pan Cam in the backyard has been reliable. I sometimes have connection issues with it, but not nearly as much as with the Front Yard V4 Pan Cam, even though the Backyard V4 Pan Cam is far more exposed to the weather.
Many cam models (I believe the v4 is one of them), if they lose connectivity, the cam should reboot after 30 mins. My v4 stays online all the time, so I would check your wifi signal and settings.
