Hi. After getting home and turning off all cameras and notifications, I now notice events in my event log.
I turned off all cameras (via shortcut) at 8.41pm (shortcut history shows successful actions) then as of 8.51pm I see a lot of events for sound and motion from one camera up until I actually turned on my cameras again. I received no notifications of these at the tome and it all comes from one camera and nothing from the other. Has anyone ever had any issues with a camera turning itself on without being told to do so?
I only see this issue when the power cable is not fully seated and it keeps powering on and off.
Thank you. I will check that. It has only happened the once that I know of but definitely worth checking
If everything is correctly seated, try this:
https://support.wyzecam.com/hc/en-us/articles/360014440692-Factory-reset
