All my Cam Plus’s stopped recording to internal SD card. I don’t care about recording to the cloud, I just want to save video to my SD card. The OEM software had this included but it stopped working. Can you tell me exactly how to turn this back on ?
A couple of questions to narrow down the possibilities if this doesn’t get you back up and running:
- Did you recently update the firmware?
- What Cam Model?
- What Cam Firmware Version?
- What App Version?
- Did you try and reformat the cards in the cam?
The SD Card Settings for most cams are in each Cam Settings , under the Advanced Settings at the top.
