Cam Plus Lite cloud playback ALWAYS stalls -_-
Seriously, will the problems ever stop?
Playback of 12s cloud clips almost never works now!
Playback will start then stall with a spinning wheel and very small (varies) data number that is just frozen there. I can play back clips fine from SD cards thru the app but almost never able to play the cloud recording. This is a new problem and started recently in last few weeks.
  • All Cam V2s firmware 4.9.9.1851
  • iOS app is up to date
  • Rebooted router multiple times
  • Recordings play fine without issues from SD cards.
  • Live view works as expected.
  • Problem is identical on independent WiFi networks, cellular data (ATT and Verizon)
  • Cams are all set to continous recording
My four version 1 battery powered WCO are all on Cam Plus lite and the 12 second cloud videos all play instantly and without issues, I’m using iOS. Must be a V2 cam issue ???
I wish I knew!
