Cam Pan V4 Button Cover Missing
My Cam Pan V4 stopped working after the last storm. I went out to check, and the push button cover was missing. I disconnected the camera and tried to get all of the water out, and waited 4 days before trying it again. Still not working. Any other ideas?
I had a Panv3 that got water in it and leaving it in a bag of rice in a warm area for 24 hours got it working again. But there wasn’t a ton of water in it either, just a bit.
If it is under a year they should replace it under warranty.
@tuttlebob Since it was a storm, I’d rule out the power side before writing off the camera. If that outdoor outlet is on a GFCI, check that it didn’t trip. Then plug the adapter into an indoor outlet with a different USB cable and see if the status light comes on at all. A surge can take out the adapter or cable and leave the camera fine. If there’s still no light with known good power, the water probably got to the board, and it’s worth telling support the button cover came off in the storm.
