Cam pan v3 waypoints are offset (eventually) if motion tracking is enabled
when i turn on the motion tracking, and wyze cam pan 3 tracks motion to outside its motion range, the saved waypoints are offset and become useless.
i have to “reset” the camera positioning by directing it to look all the way up and all the way down, then the waypoints are correct again.
i’ve lost many motion events due to the waypoints are pointing to the wrong direction (ceiling) :frowning:
worth noting that this used to work flawlessly, just starting to show this symptom the last couple months
please help!
I believe it’s been an on-going issue for a while now with the Cam Pan v3.
What you can do to mitigate this issue for now is set up a Rule as per @edmcman:
