Most of the app preferences/settings are stored in the cloud.
Same here. When I re-order within a group it doesn’t stick to my preferred order after saving. Noticed it started 1/15/2026.
I don’t think that’s very smart, app preferences should be local.
Same issue for me as well…
Same here. Seems to default to the order of activation. Frustrating glitch. Please fix this Wyze.
Ditto. Except my “default” sort order appears to be by camera type, not necessarily by activation date. Mine always reverts to the V4 at top, then the V3 cams, then the OG – this is the case every time after I set my desired order, go to Home then go back to my device group. Please fix! ![]()
Same issue for me, iPadOS and Android.
Has anyone contacted Wyze Customer Support to report this issue? If so, please post your Support Ticket number so we can escalate this issue up the chain.
Wyze engineers have been made aware of the issue and are working on a fix.
This. you can backup my preferences to the cloud, and if my device doesn’t have them, or if I press a button you can sync them down to the device, but don’t make it pull from the cloud to know what order I want them shown to me every time I open the app. That’s a ridiculous design pattern, and shows me why they are always crying about cloud costs if this is how they operate…
It pulls once unless you kill the app or restart your device. Authentication.
Pretending issues don’t happen with normal use does appear to be standard operating procedure for Wyze employees. but a lot of people close background apps when we aren’t using them, and a lot of phones do this automatically to free up resources. But I guess its easier to pretend I’m crazy than to update your code.
The issue has been resolved. If you are still experiencing this issue, please restart your app and/or phone/tablet.
You are better than David Copperfield. Amazing.
I restarted App on one phone and the other phone was also fixed.
(Funny thing is I always kill my running apps during the day.)
Confirmed fixed for me. Thanks.
Fixed - thanks!… now, only if they will fix the issue of the Duo Cam Doorbell getting stuck on “Loading Live Stream”.
Here’s what worked for me.
Go to the devices tab. Click or press on the stars that make the cameras your favorites, including the Wyze Group. Now rearrange the cams by long pressing on each camera to put them in the order you wish. Once done you can then make each one your favorites again along with the Wyze group.
Sometimes you may find you must arrange them in reverse order to get them in the order you wish.
This is what has worked for me on my Android 15 phone.
How it works for you too.
