How would I sort these to my liking?
This is theEVENTS tab in the app,
Then I choose the group I want to see EVENTS from.
So how do I adjust and sort these groups so that HOME is first, then SHOP CAMS is second and so on?
The order is based on how they are setup in the Device Tab on the Home Screen.
Go to the Home Page, Tap on Devices. The Put the Groups in the order you want. After you do that, the Events Tab Filter Screen will show you the list in your specific order.
That solved it. Thanks.
My Pleasure. Glad it worked
ME again. I am here with a new yet same issue.
Today without updating the app, the app just changed on me and now there is a FACES in the events tab and the order of the camera groups has changed and this time there is no fixing it.
Any ideas why it now looks like this?
Hello.
I have the same problem with mixed-up/unsorted/jumbled cameras and camera groups under Events > (filter by) Cameras.
Some time very early in the morning of Sep 13, 2024 a “Faces” option in the Events tab was added.
Later that same morning, I noticed that the cameras and camera groups were all mixed and jumbled up.
I tried changing the order of the devices and groups under Home > Devices. This made no difference. I re-ordered every camera and every group under Devices.
I also tried enabling and disabling the favorite option on some of the groups and cameras.
I also tried the following: restarted my Android device (pixel 7); updated the Wyze app to the latest-- 3.1.0 (564); forced stop and then cleared cache of the Wyze app; updated Android 14 to the Sep 5 patch; more restarts of the app and phone; restarting cameras.
Unfortunately, the groups and cameras are still jumbled up. The mixed-up order isn’t alphabetical, is not sorted by activation date, nor is the order based on camera model.
When Wyze fixes this, I hope they also move the Faces option to the far right. The option to sort by Camera has not been partially pushed off the “edged” of my mobile device’s screen.
Thank you.
I have the same problem. I have to change the cameras I view in events often. Far more than I would person/ faces, or motion. My sort order is not the same as the home cameras and nothing I do will change it.
