Cam with the latest updated firmware keeps reconnecting.Throughput goes up to 112KB/s and then drops to 0.0KB/s. Then it goes through the reconnection/authentication cycle again. This happens constantly every few seconds. The camera is sitting literally next to the router (Asus TM-AC1900).
Firmware: 4.9.2.52
Signal strength: 96%
I have another cam where I haven’t updated the firmware and it works just fine all the time even though it’s on a different floor from the router.
Firmware: 4.9.2.25
Should I downgrade the firmware? If so, where do I get the .25 firmware and how to downgrade? Any risks of downgrading? This problem occurs only when on LTE, but I need to troubleshoot more to confirm. I don’t know the color of the LED indicator. Sometimes there is a message stating that the network is not stable, switch to 360p, but only on the problematic camera.
Awesome! Thanks for the info. I didn’t see a link to the 4.9.2.25 firmware in that post. Do you know what is the last known stable firmware for v2 cams?
I am assuming that no one else is having this issue? That makes me wonder if I actually have a bad device.
I have also seen problems when multiple access points use the same SSID. Works well for laptops that will roam, but many of my IOT devices seem to eventually get confused and go offline. My solution was to create guest networks with unique SSIDs on each AP and connect to the SSID that has the strongest signal…
My issue is that this problem occurs only on the camera with this particular firmware version. The other camera with the older firmware seems just fine.
I also created a support ticket 3 days ago and am waiting to hear back. Hopefully the official support team has a proper resolution. I will post back here to let everyone know.
