Wifi connectivity bug introduced somewhere between firmware version 4.9.9.1433 and 4.9.9.1851. On 4.9.9.1851 cameras will never re-connect to WiFi after a power down/reboot, they will only connect to WiFi on the initial setup process. Any subsequent power down/reboot they will just sit there blinking amber/blue for hours. My WiFi network hasn’t changed and confirmed this behavior on 3 separate V2 cams. Downgraded to 4.9.9.1433 and they connect just as they should and appear to work fine after multiple power down/reboots.
can you go back to 4.9.8.1002
the only working firmware with app 2.31
