with each new update to the app, Wyze continues to disappoint. Firmware and app are up-to-date from what the app says.
Why would anyone subscribe when the on Cam doesn’t even work?
You tagged V3, so I assume that is the camera type you are talking about. A few questions.
Recent updates did change the V3 UI a bit so lots of people are asking questions.
Are you trying to watch cloud based events or recordings from the local µSD card?
If you have a µSD card, is the camera set to record events only or continuous?
as @K6CCC indicated, the UI for the Cam V3 has been updated to be similar to the other newer cameras. If you are not using Cam Plus or Cam Unlimited, and you have an SD Card in the camera, you will need to tap on the SD Card option to see the recordings. Note: Continuous recording would be better if you don’t have an Cam Services.
