Cam 2 stalls 3 -4 seconds into video playback
I tried your workaround and it performed exactly as you described. I agree it’s has to be a software glitch.
How do we get Wyze to believe us? And more importantly FIX IT?
If enough users report it, they can’t ignore it. If they can’t ignore it, they will have it fix it. Maybe a user survey asking if you have ever experienced this problem or if you are experiencing this problem? The survey would at least give us/them an idea of the scope of the problem.
Doug, try turning off the ICLOUD BACKUP off. This system seems to have a problem with the icloud. Good luck!!!
Why with only v2 cams and only one of my v2 cams?
Doug, I would resync it or restart it.
It’s the only options we have available to us. Good luck and hope it helps!!
I have many times. Did you see the posts from other people? Others are reporting the exact same problem.
They (WYZE) are working on this issue. It was posted yesterday. Hang on for the ride.
| doug.spindler
June 19 |
