I need a cable for v1 camera (actually it says wyzec1). Does anyone have one that I can purchase?
Welcome @timw61
Are you talking about the camera power cable?
This is called a USB A to micro USB cable.
Here’s one similar to the supplied cable:
https://www.amazon.com/gp/slredirect/picassoRedirect.html/ref=pa_sp_atf_aps_sr_pg1_1?ie=UTF8&adId=A04725741HP4LRB7L2CUQ&url=%2FAmazon-Micro-USB-designed-tablets-readers%2Fdp%2FB0741WGQ36%2Fref%3Dsr_1_1_sspa%3Fcrid%3DELO8HJB44IUJ%26dchild%3D1%26keywords%3Dmicro%2Busb%2Bcable%2B10ft%26qid%3D1611969952%26sprefix%3Dmicro%2Busb%2Bcable%252Caps%252C377%26sr%3D8-1-spons%26psc%3D1&qualifier=1611969952&id=6940862650077861&widgetName=sp_atf
Those are both USB-C cables @Brlepage .
You need USB-A to microUSB.
Here are (2) 10’ for $10 on Amazon.
https://www.amazon.com/Extension-WyzeCam-KasaCam-Charging-Security/dp/B07TKHLZHT/ref=mp_s_a_1_3?dchild=1&keywords=Micro%2Busb%2Bflat%2Bwhite&qid=1611970887&sr=8-3&ref_=d6k_applink_bb_marketplace&th=1&psc=1
You’re correct! I had copied the wrong link. ![]()
Edited to correct.
So this one (type) will work with the V1 camera?
Your response is MUCH appreciated
Yes, V1, V2 and Pan. That’s why I posted it. ![]()
Very much appreciated.
The connector is microUSB. The only problem I’ve had with aftermarket cables is the rubber around the connector being too large for the inset hole in the camera. I linked this cable because it specifically states Wyze in the description.
I have shaved down cables to fit. ![]()
