I’ve restarted the camera from a factory reset, rebooted the router, etc, to no avail.
Suggestions?
Suggestions?
What happened to cause you to try and reinstall it? I’m guessing whatever it was, it was the death of the camera (or wifi chip). That’s a pretty old cam.
You can get OGs for $15 to $20 frequently and v4s for $25 to $35, they’re a big step up. Only disadvantage is if you’re using Cam Plus Lite, they will not work with that, only SD card or the paid subscription. I use them with SD cards and it is plenty for my needs. The plain v3 (not Pan v3) is the last camera to work with Cam Plus Lite.
