Bulbs Pulsated
Right after the bulb firmware update the switch controlling 3 bulbs was turned off and on and the bulbs started pulsing from dim to bright.
After shutting the switch off for a bit and then back on, the bulbs came on at full brightness but would not reconnect to the WiFi network.
  1. Does the dimming and brightening mean something? I didn’t find anything in the forums.
  2. How do I reconnect the bulbs? Each bulb is “named” differently. I’m guessing I need to go through the whole setup process again.
Yes, that’s the normal documented way it goes into pairing mode. That happens if you flick the power off 2 or 3 times.
See also Wyze bulb setup - #24 by Newshound
