Bulbs lose WiFi
The light keeps losing WiFi and reboot fixes it. Why not add a feature to reboot if loses WiFi. Also keep the current state either on or off
On losing WiFi, you should get with Wyze support (link below) who has better tools to see if your signal at the bulb is weak (like you have the bulb far from the router, or in a metal can).
As for keeping the current state, Wyze’s intention was to have the bulb work like a regular bulb. So if power is lost, then power will come back on if power is restored. I use a bulb like that every day.
https://support.wyzecam.com/hc/en-us/requests/new
