Bulb just randomly turned off
I’m not having a good few days with Wyze products (see [here])(Contact sensor shows 'open' but not 'closed' - #3 by Zamboknee)
Now a wyze bulb that was turned on just randomly turned off on its own.
And, no, it’s not on ‘vacation mode’
Any ideas?
Just did it again.
Thoughts?
I would probably do a factory reset on the bulb. Then reconnect the bulb with a fresh setup. It may or may not help. :man_shrugging: Anyway, it’s worth a try if you have time.
All I’m seeing is ‘Remove Device.’
Nevermind. I found the ‘factory reset’ directions. I reset it and we’ll see what happens.
If it continues to blink, you may want to enter a support ticket. It may simply be intermittent.
It’s not that it’s blinking. After turning the switch on (we need to use the physical switch) the bulb would , out of the blue, just turn off on it’s own.
If a solder joint is cracked, the warming of the bulb could make it break connection. Then the cooling of the bulb would make the connection again. Just a random possibility. In any case, the bulb should not be turning off on it’s own.
I do have bulbs set to automatically turn off after a given amount of time, but obviously you would know if you did that.
I created a ticket. Thanks
