Hi,
On my Wyze v2, toggling “camera status light” under the advanced settings does nothing. I am trying to disable the blue LED on the back of the camera, which is glowing off the wall behind it at night.
Is this not the purpose of this toggle?
TIA.
Hi,
TIA.
Mine works as designed and it stays off. Maybe delete the app and reinstall it. Are you using the Beta app or production?
