Wyze Cam v3 needs a tiny bit of light for color night vision. Use the v3 Spotlight Kit when there’s no other light source around. Available now at Wyze Cam v3 Spotlight Kit!
What a bright idea!
I’m assuming that USB power has to be ran back to a power brick? It doesn’t use a splitter from the camera’s USB power?
Great news! So this is positioned as fill in lighting to supplement the V3’s amazing night vision.
Does it not amount to a reasonable floodlight replacement?
I think this is placed inline with the V3 cable.
It actually does use the same power cable! It has a snazzy method for both devices getting power from the same cable. ![]()
This is very intriguing, but I see no information about whether the spotlight offers controls or is ‘always on’ when plugged in. Will I be able to leave the spotlight off until the camera senses motion, for example?
Yes, good idea. But is it controllable from the app? Does it work on a light sensor? iFttt? Schedules? Would have ordered one one or two with some more V3 cams if I would have had more information from the get go.
The spotlight has 2 options: always on or when motion is detected.
Thanks - this info ought to be included somewhere in the product page. I would not want an always-on light in most places.
Yikes…shipping cost is 40% of the unit cost.
I wish there was a video with it in action on the page - I am interested in this but there is very minimal info on it. What type of light/bulb is it? How strong is it - what is the coverage/range of the light? It is a very small light so I worry how effective it would be, but I love the idea.
it doesn’t have light bulb it is an LED
coupled with the starlight sensor in the camera it is pretty effective
Wyze Cam V3 Spotlight Kit
Tech Specs
- Lumens: 70 lumens
- Angle: 130 degrees
- Power supply: 5V 1A
- Dimension: 21.555.834.4mm
- Connection: Micro USB
- Rating: IP65
- Number of LEDs: 5
- Light temperature: 4000-5000K
- Operating conditions: -4°F to 131°F (-20°C to 55°C)
- Warranty: 1 year
In the Box
- Spotlight
- USB cable splitter
Pic with USB cable splitter
Functionality
- Toggle on and off manually using the Wyze app.
- Automate using Rules in the Wyze app.
- Switch between low and high brightness levels.
- Control with 3rd party integrations such as IFTTT.
- Use Cases.
- Turn on the light automatically when motion is detected using Rules.
- Automatically turn on the light at night using Rules for better visibility, then automatically turn it back off.
- Use low brightness for enhanced indoor use, then bring your cam outside and switch to high brightness for enhanced outdoor use.
Settings in app
USB cable splitter connects power to the camera and spotlight.
Any update on the outdoor cable? I couldn’t find it anywhere in the Shop now? Can the cable that ships with the Cam v3 be used outdoors, or is that a no-no?
Yes it is designed to use outdoors and has a weatherproof boot that goes over the connection to the camera
So what’s the advantage for the outdoor cable. Just extra distance?
I don’t know what outdoor cable you are referring to
Any idea when the outdoor cables will be availble? Would like to order 3 spotlights and three outdoor adapters togethe and not have to pay separately shipping.
OK gotcha.
I Have no information about it , or when it will be available
