Bright light captured
Looks like some high-powered LED or flashlight on your property. You can tell the light is close and on your property instead of far away on the mountain in the background because of:
  1. The difference in the flaring on the grass and nearby objects. If the light was far away, the flaring would be more equal because the difference would be almost irrelevant, but since there is such a difference in the flaring here, the physics of how light works proves the light is really close.
  2. The brightness and spread is more characteristic of a nearby source. Distant lights tend to diffuse over distance and would not create this level of stark contrast in brightness.
  3. Angle of illumination suggests it is located relatively close to ground level and couldn’t give the same effect if it was farther back as it would illuminatethe area differently and from a much shallower angle. It would be obvious it was higher up…but the angle of the light spread can help us judge the distance and height here.
  1. Details visible around the light vs increasing distances from it. For example, surrounding objects like the red and green items are well lit and clearly visible. A Distant light would not provide this level of illumination for such nearby details differently from others that are virtually the same distance.
If you check surrounding events or during the day time you will be able to figure out the source of the bright light if you don’t already know. Can you review the SD card back to when it first appeared and disappeared? I’m curious now if you know, what is the light for on your property or the neighbor’s property?
This was recorded in 2020 and can’t get into that account just have it on my phone so just posted it it’s really 35 min long
Looks like a drone.
