I did hard reset and deleted then reinstalled the app. It says that it can’t do 5g? Was working fine yesterday
First thing I would check is what changed with your WiFi?
Do you mean the 5ghz WiFi band? The V3 and OG cameras should connect on the 2.4ghz band.
