Living on a boat I have a lot of systems to monitor. The new Battery Cam Pro has given me an opportune way to observe systems in the bilges (I have 6) without moving “heaven and Earth” to get access to those hard to reach areas on a regular basis. In one bilge I have tanks and plumbing that I like to monitor and in another I have electronics and house batteries. The charger for my batteries is difficult to get at to check on charging and battery status, So I installed the Battery Cam Pro which has a light and does not require connection to a power source. I can see the whole area with the wide angle view and the photo quality allows me to zoom into the charger monitor to see the numbers. I can also monitor the bilge for water incursion and other issues that may be present in this place that is hard to get at daily, especially when I am away! I will have these cameras in all six separate bilges to monitor every thing!!
Smart. I bet the folks on the Mayflower would have used Battery Cam Pro too if they had it.
