Bluestacks 5 Failed to connect
when starting the app on Bluestack all cam are failed to connect.
But if i click on any of yhem it is working !!!
is there a setting i should change to see all cam at the same time ?
thanks
Welcome to the Forum, @jean.s2011! :wave:
What additional detail can you provide about your settings and troubleshooting steps you’ve attempted? For instance…
  • What happens if you use the app on an actual mobile device running Android?
  • Where are you experiencing the error? Favorites tab, individual device screen, viewing a camera group?
  • What error code (if any) or message does the app show?
  • Do you have  Account ➜ App Settings ➜ Auto Play Video Live Streams enabled?
Knowing more about your experience would be helpful for others who want to assist. If you can provide (a) relevant screenshot(s), then that might be even better.
As far as I know, the Wyze app isn’t officially supported on emulators, though some Forum members report using them routinely, so I imagine there’s probably a solution for your issue.
Nice avatar shadowing.
There was some discussion of that error code in another topic last month, starting around here:
There’s some discussion from users about seeing this in previous beta app releases and about changing some Developer options settings in order to improve performance. I haven’t seen a mention of what Wyze app version you’re using, so I don’t know if that will be helpful or not.
Thank you for sharing the screenshots!
it is 3.3.6(626)
Events had not been populating Events & Monitoring (Multi-Cam Timeline) tabs. With the hotfix, it’s working again.
