Blue indicator light on camera not functioning
Blue indicator light on camera no longer functioning. Amber light does come on at startup only.
Settings are set to be on.
Please advise.
Thank you.
You might want to double check the settings. After a recent update one of mine was off. I’m pretty sure I didn’t turn it off by accident. Turned it back on easily.
Thank you, however this was the first thing I checked. I think it may be the LED itself, however the life expectancy of an LED is very long.
Hi, I have the same issue with the blue light indicator. The camera works but the blue light is dead. Do you know which setting that will make the blue light comes back on? Thank you.
SEE
Camera Status Light
Thank you. I did find it and fixed the issue.
Thank you this helped me too!
Camera Status Light is ON, however nothing showing on blue indicator light.
