Now just added a black line or dark purple across the top of one camera. I redid my internet connection from scratch and it was ok but after a few minutes was back. Is this a known thing?
Whack the sides of your cam a few times, switch Night Vision mode on/off a few times, then try placing it right side up or upside down instead of sideways.
Have the neighbours stopped harassing you?
None of that worked. They are blocking email login on mt 2nd phone. They would love to ruin my security cameras.
If I had your neighbors, I’d surprise them by building my own 200 kV EMP pulse blaster.
Not legal and you’ll probably end up with cancer and destroy your own electronics unless shielded with EMP blankets, but it’s not difficult. DIY plans are out on the Internet.
You’ve admitted to tearing magnets out of the cams and other destructive things. You can’t then come here and ask why they’re broken.
I did not tear I removed at the recommendation on here. I used those batteries. to this day to remove colour that used to work but not now, the pink colour is brought pink when facing the window but turns blue when camera is turned away from window. My
Retreat ![]()
The black line is now blue.
Is the camera is any type of case or cover? Is there anything on the front of the camera?
If I’m not mistaken that post is about the doorbell not about the cam V3.
Its not the post i saw long ago. it was a reply to a post i made but said the same thing.
That’s one weird and unusual contraption ![]()
+1 for knot-tying skills ![]()
Reset camera didn’t help.
