Best dynamic range among current cams?
My favorite cam is a V2 for their great dynamic range. My V3 blows out details on sunny days. Dont need lots of features just fairly wide angle and good dynamic range to capture details.
Is there a current cam with the same or better dynamic range of the V2?
I never had a V2 but I have V3, V3 PRO , WCO v1 and V4 cams. You may want to look at the Specs. of the V4, it has a wider field of view (115.8 degrees) than the 2 and has Wide Dynamic Range. Just check out the available information. I have two V4 cams and like them both. The only thing I do not like about the V4 is if you turn on the spotlight or the cam is exposed to really bright light at night it will darken the background for a few seconds really fast then return to a good view. Daytime time videos are A+.
