Hi, I had my base station in the room for a couple of years and the cam outside, worked great. I unplugged the base station to paint the room, when I plugged it back in, it didn’t reconnect. I connected it with wire to router and it doesn’t want to connect. I plug it into the modem and it connects, but when I unplugged it to move back to the other room where it has been for years, it doesn’t reconnect. I also tried to delete device and start new, but same thing doesn’t connect when you take the cat wire out of the modem. HELP!
Don’t delete the Outdoor cams if they are offline. If you do, you will NEVER be able to add them back to your account. This is an anti-theft thing.
