Base Station not accepting wifi password(s)
Base Station for Outdoor Cam has never accepted wifi password, just says “Failed” as soon as pw entered. Has continued thru many, many tries to be sure pw is correct, and still happens even with new upgraded network. Functions over ethernet cable, but remote connections are spotty. Hoping if we can connect base stn wirelessly we can move it closer to camera and improve consistency w remote connections, HD capability, etc.
Is your wifi 2.4 or 5.0? Wyze only works on 2.4.
I’ve read here that the SSID (network name) can’t have spaces, and there may be some character limitations on the password as well. Try changing them and see if that helps.
I need to check it but I think we’ve had same issue on both 2.4 and 5. Will check current setting once we get back out to that location. Thanks much for the reply and info.
I have this same problem, however, my phone does not seem tro offer 2.4 vs. 5.0
