Hello I have a Baldwin prestige lock & the screws Will not going to the Baldwin lock. The bracket provided lines up with two lower holes and I remove those screws but they provided screws or not the correct thread and length. Is this lock set is compatible with the wyze lock?
trekgod3
Sounds like you answered your own question. Return the wyze lock or swap out your lockset
Related topics
| Topic | Replies | Views | Activity | |
| Wyze Lock Compatibility with Baldwin Deadbolts | 8 | 1096 | December 17, 2020 | |
| Wyze lock deadbolt compatibility question | 1 | 386 | February 28, 2020 | |
| Wyze lock manual lock and unlock problem | 3 | 736 | May 12, 2022 | |
| Unhappy with "updated" Wyze lock; replacing with a different brand | 0 | 77 | August 20, 2025 | |
| Compatible outside door lock for Wyze smart lock | 0 | 333 | April 16, 2021 |
