Balcony Rail mounting of Outdoor Cam
I was wondering if anyone has a solution for mounting an outdoor cam on a metal balcony railing. Thanks.
@warren128 Welcome to the Wyze community! :slightly_smiling_face:
You can take a look at this flexible mount and see if this will work for your railing. A good example in this pic here.
2 Pack
https://www.amazon.com/dp/B085CC63KQ/ref=cm_sw_r_cp_tai_XulKFb44WGY3M
Welcome to the Wyze community @warren128!
I like @StopICU33‘s idea!
You could also use a bar mount for an action camera depending on the size of the bars.
https://www.amazon.com/Camera-Compatible-Action-Geekpro-Cameras/dp/B07TJFS1C9/ref=sr_1_6?crid=3GPHREXTVQBJ6&dchild=1&keywords=action+cam+handle+mount&qid=1603329417&sprefix=Action+cam+handle+%2Caps%2C162&sr=8-6
zip ties!
Thanks for your suggestions! I think the Arlo flexible mount may work for me. So the tripod socket on the Wyze outdoor cam is a standard one that also fits the one on Amazon for the Arlo, right?
Yes!
@Brlepage is correct.
It’s the standard 1/4"-20 Male thread and it will fit the outdoor cam. :+1:
I think I’ll try one. It will have to undone from the balcony every two months, hopefully it will hold up.
On my initial test of a fully charged outdoor cam at my balcony spot, it lasted just over 60 days before it needed a charge.
Thanks again, I just ordered one of those flexy things from Amazon.
You’re welcome! I think it’s the best solution if you plan on moving the camera around. Also it makes it easy to take down and charge the battery.
I can definitely vouch for “these mounts” I have 3 cameras mounted with them and, I sometimes move them around, they work great .
Also have a couple of these Flexible Twist Mount
https://www.thelightsource.com/products/micro-clamp-19
Hi holocron.
Since both screws on this micro clamp are 5/16 ø, how is it to attach to the cameras standard 1/4x20?
