Im looking for options as far as connecting something to the bottom of the Wyze cam outdoor - similar to those snake-like attachments so I can wrap around a tree branch rather than screwing into one…anyone found anything good already? Thanks
Could something like this work:
https://www.amazon.com/Koroao-Flexible-Twist-Mount-Ultra/dp/B07Q297MHL/ref=sr_1_14?dchild=1&keywords=arlo+tree+mount&qid=1599002861&sr=8-14
You just have to hang the camera upside down and use the tripod screw.
This should work. I think @HDRock has used these with his cams.
https://www.amazon.com/dp/B082HKMVZ9/ref=cm_sw_r_cp_tai_zsWtFbENCB2YB
The best way to mount the Cam Outdoor is with cable ties. The screw is to small and is only useful for mounting on a building.
I wonder how well the plastic in those cable ties will fare with UV exposure. I’ve found some plastics can become quite brittle.
