Attaching Wyze Strip Light Pro to Inside of a window facing out
Has anyone attached a Wyze Strip Light Pro to the Inside of a window facing out?
I am considering these to attach them as Christmas Lights for the season, then take them down, leaving the clips in place, but these appear to have a white double sided tape, so I don’t think that’s going to work for me:
Wingture Self-Adhesive LED Strip Light Clips 15mm
[/quote]
I’m thinking or trying this instead to hold the strip to the window, hopefully this will hold up till January:
Alientape Pre Cut 96 Piece Set
As apparently they are removable.
Anyone else have any suggestions on how to make this work?
SJ
